Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1596 Discussions
Gen12LP device selection timeout
REGULY__ISTVAN
I am trying to run SYCL code on the Gen12LP devices in the devcloud. However, queue creation takes a very long time, or even gets stuck. Even running "clinfo" will get stuck when querying the Gen12LP devices. This happens on several different nodes of devcloud, including s011-n001, s012-n001. On s011-n002 clinfo simply segfaults. On s011-n006 clinfo does not report any GPUs available
I do not have anything in my shell environment that should affect this.
To reproduce: run clinfo, or the simple-sycl-app.cpp from https://intel.github.io/llvm-docs/GetStartedGuide.html modified to select the GPU.
Istvan
Gopika_Intel
The issue has been fixed from our end. Please check if your issue has been resolved and also give us a confirmation about the same.
Gopika
Gopika_Intel
Hi Istvan,
Thank you for using the Intel Devcloud forum. Sorry for the inconvenience caused. We’ve connected with the internal team. We’ll get back to you.
Gopika
Gopika_Intel
Gopika
REGULY__ISTVAN
Gopika_Intel
Hi Istvan,
Thank you for the confirmation. We would no longer be monitoring this thread. For further queries and issues please raise a new thread, we’d be happy to help you.
Gopika
