Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1642 Discussions
Getting downloaed notebook into devcloud area
so1
This is my scenario
1) i joined intel devcloud and got an account. I use cygwin to ssh devcloud.  This is working
2) as part of tutorial exercise i downloaded this real_time_sensor_fusion_for_loss_prevention.zip onto my laptop.  This also worked. Copied from here: https://software.intel.com/iot/edgesoftwarehub/download/home/ri/real_time_sensor_fusion_for_loss_prevention
3) I needed to copy it over to my terminal from my laptop and I used this command:
scp <localpath> devcloud:~/    This also worked.  The location is /home/u130776
4) Then I went to https://notebooks.edge.devcloud.intel.com/user/u134414/lab and it has only reference-samples.  I needed to get what is copied either in step 2 or step 3 into the above area.
Q1: Is there a way to directly downloaded into my cygwin from the https area
Q2: what is the way to get what i downloaded from item 3  or 2 into area 4 so that i can use the jupyter notebook framework
It looks like a simple task to do - but not sure for the same account as mine, i seem to be in two areas and unable to move data around
Srinivas
ChrisB_Intel
I sent you a private message. Please take a look.
Chris
ChrisB_Intel
Chris
