Community
cancel
Showing results for
Search instead for
Did you mean:
Gao__Chao
High Level architecture
if I want to do hardware analysis within one devcloud nodes, I was wondering where can I find the high-level architecture for intel devcloud? Like how FPGA and Host are connected, or it is not publishable?
Chao
ChithraJ_Intel
Hi Chao,
We have informed this to concerned team and will get back to you soon.
Chithra J
ChithraJ_Intel
Hi Chao,
To know more about Devcloud configuration and high level architecture of Devcloud, you can refer to the below link: https://devcloud.intel.com/oneapi/
Also, running the pbsnodes command will help you to understand available nodes and it's configuration. The status of each node will change dynamically with time to time.
Chithra J
ChithraJ_Intel
Hi Chao,
Has the solution provided is helpful? Could you please give us an update on this?
Chithra
ChithraJ_Intel
Hi Chao,
We are assuming that the solution provided helped and would no longer be monitoring this issue. Please raise a new thread if you have further issues.
Chithra
