Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1273 Discussions
How can I swap between different target hardware(CPU,GPU)
pihx
I want to compare performance between CPU and GPU, training a NN with Tensorflow/Python.
How can I select target HW from Python running in DevCloud from a Terminal?
Hari_B_Intel
Hi Pihx
Regarding your question on obtaining example resnet18_benchmark_job.sh, you can refer to any of the Intel DevCloud example applications which will show you how to submit the job.
Basically, qsub command is part of the Linux command, you can get more detail about qsub here https://man7.org/linux/man-pages/man1/qsub.1p.html
You can submit the python script to qsub, but the bash script can help in customizing the parameter for the python script.
Also from the picture you have shown, it seems that the error "qsub : script is written in DOS/Windows text format" is due to unprintable end-of-line characters which may be misinterpreted by Linux command interpreters.
To resolve this, you can use dos2unix on windows or Linux machines to convert the windows interpreters to Linux interpreters. After that, you can try to submit the job.
DevCloud Example code : https://cdrdv2.intel.com/v1/dl/getContent/678623?explicitVersion=true
Hope the information help.
Thank you
AlekhyaV_Intel
Thank you for posting in Intel Communities. Could you please let us know which DevCloud you’re using? Is it DevCloud for oneAPI/Edge/FPGA?
If you're using oneAPI for DevCloud, please follow the below steps:
By connecting to specific compute node which hosts GPU/CPU, you can train your model & observe the performance difference. All you must do is connect to a GPU supported compute node. After logging in to devcloud, please try the below command to get connected to any available compute node with GPU:
qsub -I -l nodes=1:gpu:ppn=2 -d .
To connect to a CPU,
qsub -I -l nodes=1:cpu:ppn=2 -d .
Hope this helps!
Thanks & Regards,
Alekhya
AlekhyaV_Intel
Has the solution provided helped? Could you please give us an update regarding this issue?
Alekhya
pihx
I am using DevCloud Edge- Terminal. And both commands gives me an error.
qsub: submit error (Job rejected by all possible destinations (check syntax, queue resources, ...))
What do I do wrong?
Hari_B_Intel
Hi pihx
In DevCloud for edges, you can submit the job to the specific hardware you would like to use.
Here are some examples of commands you can use;
qsub resnet18_benchmark_job.sh -l nodes=1:idc045 -F "results/INT8 CPU async INT8" -v VENV_PATH,OPENVINO_RUNTIME
Please make sure you're pointing to the script you would like to compare with a different devices and specifying the nodes (Platform).
Hope this information help
Thank you
pihx
Hi Hari_B,
Thanks for your reply. I don't know how to submit a job. Please, Where can I see the content of an example [resnet18_benchmark_job] .sh script and where to see the parameter documentation for qsub command? Or more precisely my goal is to run the "python myst2.py" command and measure the time it takes to finish with only CPU and with only GPU(or CPU+GPU, if GPU only is not possible)
Cause of Error: The .sh should just be LF, not CR+LF, right?
Can the submit job be a python script, or do I need to put my "python myst2.py" inside a .sh script?
Thanks for any advise!
Pihx
Hari_B_Intel
Hi Pihx
Thank you
Hari_B_Intel
This thread will no longer be monitored. If you need any additional information from us, please submit a new question.
