Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1800 Discussions
How can we check OneVPL samples on Intel dev cloud ?
krakrk
How can we install and test OneVPL samples on intel dev cloud as i am not able to install OneVPL from github because it requires root permissions on that machine?
SreedeviK_Intel
Thank you for posting in Intel communities.
We are working on this internally and will get back to you with an update shortly.
Sreedevi
SreedeviK_Intel
We can install and test oneVPL samples on Intel DevCloud using the below steps:
1. Run the below command to set environment variables:
module load vpl/latest
2. Git clone oneVPL repository on DevCloud
3. Go inside clone repository and make a directory named build:
cd oneVPL
mkdir build
cd build
4. Create binaries with help of Cmakelist.txt
cmake ..
make -j$nproc
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
Sreedevi
SreedeviK_Intel
We have not heard back from you. Could you please give us an update? Is your issue resolved?
Sreedevi
SreedeviK_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Sreedevi
