Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1516 Discussions
How to Transfer files from Local device to server
Mohsin__Muhammad
Hi
How can I transfer files from local device to remote Intel server
STyur
Hi!
The answer - at the end of this page:
Connect from Linux/macOS/Cygwin (SSH)
Rohith_K_Intel
Hi Mohsin,
Did the solution in the Devcloud documentation page, which Mr.Tyurin mentioned above, worked for you or still facing difficulties?
ie,
scp /path/to/local/file devcloud:/path/to/remote/directory/
where 'devcloud'  corresponds to the hostname in your ssh config file.
Aditya
Student Ambassador
Hi Rohith/Mohsin,
Is there any way to use filezilla or any other with client instead of using scp?
