Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1695 Discussions
How to change from xeon cpu to a gpu ?
Renan1
I'm using the command to the terminal of DevOps but it isn't changing to a cpu.
qsub -l nodes=1:gpu:ppn=2
JaideepK_Intel
The command you used is correct( to access gpu nodes). All the GPU nodes on Devcloud have CPU
To get interactive shell, use the below command:
qsub -I -l nodes=1:gpu:ppn=2
To check cpu details use the below command.
lscpu
if you want to know what are the devices available(fpga/gpu/cpu) on your node, use the below command
sycl-ls
To know more about Devcould job submission commands please go through the below documentation
link: https://devcloud.intel.com/oneapi/documentation/job-submission/
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issues. Thank you!
Jaideep
JaideepK_Intel
I hope you are doing well.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
Jaideep
JaideepK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
