Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
How to import file from google drive or kaggle dataset using Intel DevCloud jupyter environment?
Toky__Adnan
I'm trying to load datasets from kaggle datasets or google drive. I'm using Intel DevCloud jupyter notebook. How can I do it?
ChithraJ_Intel
Could you please create a conda enviroment using the below commands and follow the same steps as suggested earlier
conda create -n my_env -c intel python=3.6
source activate my_env
pip install kaggle --user
Hope this helps for you.
ChithraJ_Intel
Could you please try out the below steps to access Kaggle API in devcloud through command line.
Step 1: Install kaggle using pip as follows
Now, run
kaggle -h
to check whether it is installed successfully.
Step 2: To use Kaggle API, create an account in kaggle official page(https://www.kaggle.com). Then, go to "My Account" tab of user's profile and select "create new API token". This will download the kaggle.json file in your system.
Step 3: Create a .kaggle folder in devcloud home folder
mkdir .kaggle
Now, copy the kaggle.json to that folder.
Step 4: In order to download kaggle datasets,first search for your desired dataset using the below command in devcloud terminal
kaggle datasets list -s [KEYWORD]
        Eg: If you want to download creditcard fraud detection dataset, then search like this
kaggle datasets list -s credit
        It will list all the datasets available with this keyword.For example,
        isaikumar/creditcardfraud                            Credit Card Fraud Detection Dataset                  66MB  2018-05-05 09:38:01           1797         30  0.5882353
        ananta/credit-card-data                              Credit Card Data                                      1MB  2018-08-24 02:22:36           1218         15  0.64705884
        wendykan/lending-club-loan-data                      Lending Club Loan Data                              720MB  2019-03-18 18:43:12          68843       1238  0.7352941
Step 5: To download the dataset titled "Credit Card Fraud Detection Dataset",
kaggle datasets download isaikumar/creditcardfraud
Hope it helps. Please feel free to reach out to us for further issues.
Toky__Adnan
When I run the command
It shows the following error message:
OSError: [Errno 30] Read-only file system: '/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/tqdm'
Not only for this command. The same error message shows for pip install something. Please help me.
ChithraJ_Intel
Toky__Adnan
Thanks a lot. It has been fixed.
ChithraJ_Intel
Could you please confirm whether you are able to download kaggle datasets without any issues using the solution provided.
Toky__Adnan
Yes. I'm able to download kaggle datasets without any issues using the solution provided. Thanks again.
ChithraJ_Intel
Thanks for the confirmation.
We are closing the case. Please feel free to raise a new thread in case if you face any further issues.
