As showing in the screenshot below, now I'm at the position of login-2, and I has submitted a job call walltime.sh then got the job ID.
The question is how I can login in the computing node (sXXX-nXXX) about this job ID?
I has read some instruction but it's so hard for me to understand. Anyone could help me? Thanks.
Best wishes,
Mo
Hi Fernando_Mo,
Can check the wall.time.sh.o in the same directory of wall.time.sh? It will specific the nodes that your job is running on.
Aik Eu
Hi @aikeu
Thanks for your respond. Yes, I have checked it, there is showing a specific node and has been runing on.
However, I just wondering, how to login in it again by some command. As the below screenshot, I don't want to kill this process, I want to re-login in. What command line I can use for it? Thank you very much.
Best wishes,
Ganyong
Hi Fernando_Mo,
If I understood correctly what you are trying to do,
I think you can try to perform Deleting Jobs on the Devcloud as referring to this document:
Aik Eu
