Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1520 Discussions
How to register with employee account?
Qiang
I met some issues when I try to active devcloud access.
I can login to devcloud with employee account, the website show error message about "Looks like your account is not registered. Kindly register you account and try again.".
And after I clicked the "Register for Intel DevCloud Account" button, it redirect to an error page about "This enrollment form is only used by external users and not employees.", and then I can't go further.
So how can I active devcloud with employee account?
Thanks!
RemyaP_Intel
Thank you for posting in Intel communities.
Looks like that was a temporary issue. We are able to see the registration page now. Could you please try again to register for OneAPI devCloud.
Link : https://consumer.intel.com/intelcorpb2c.onmicrosoft.com/B2C_1A_UnifiedLogin_SISU_CML_SAML/generic/login?entityId=www.intel.com
Remya Premdas
RemyaP_Intel
Remya Premdas
Qiang
Hi Remya,
I can't verify it now.
I think the containerized devcloud link is "404" error now.
https://www.intel.com/devcloud-containers
Could you check on it?
Thanks!
Qiang
RemyaP_Intel
Could you please confirm which DevCloud you are trying to register for. Is it oneAPI/ Edge DevCloud?
Remya
Qiang
Hi Remya,
I don't know the reason, but I found both of oneAPI and Edge DevCloud works for me now.
Currently only the "FPGA" cloud still has same issue, but so far I don't need it.
https://software.intel.com/content/www/us/en/develop/tools/devcloud/fpga.html
Thanks!
Qiang
RemyaP_Intel
Glad to know that. Could you please confirm whether your issue is resolved or not.
Remya Premdas
Qiang
Hi Remya,
The oneAPI & Containerized devcloud works well.
But the link for FPGA still doesn't work.
This link redirect to an error message about "This enrollment form is only used by external users and not employees."
Do I need any other permission to access FPGA devcloud?
Thanks!
RemyaP_Intel
Separate access request for FPGA DevCloud is not required. You can use it by running the below commands in oneAPI DevCloud.
>> source /data/intel_fpga/devcloudLoginToolSetup.sh
>> devcloud_login
And then select the appropriate number to proceed.
Otherwise, you can run
>> export PBS_DEFAULT=v-qsvr-fpga
And to connect to any available FPGA nodes, use:
>> qsub -I
Remya Premdas
Qiang
RemyaP_Intel
Is your issue resolved? Can we go ahead and close this ticket?
Remya Premdas
RemyaP_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Remya Premdas
