Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1524 Discussions
How to repopulate my /home to the execution of Jupiter oneAPI notebooks?
Illya
My /home directory is empty. When I try to run various Jupiter oneAPI modules, the system reports the oneAPI_essentialmodule01 for example, the path cannot be found.
Where do I get these jupiter notebook modules from ?
AthiraM_Intel
Please find the below path where the oneAPI_Essentials folder is present:
/data/oneapi_workshop/oneAPI_Essentials
You can copy the folder to your home directory by the below command:
cp -r /data/oneapi_workshop/oneAPI_Essentials ~
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
AthiraM_Intel
We could see that you have raised another thread with the same issue. That issue has been marked as resolved.
Could you please let us know whether this is a duplicate case of the below thread: https://community.intel.com/t5/Intel-DevCloud/How-to-repopulate-my-home-with-the-oneAPI-program-examples/m-p/1452616#M7245
Illya
I thought I had solved the issue but after get the oneAPI samples, I found it was not solving the missing directories to run Jupyter notebooks. I still need the /oneAPI_essentials/0xxx content I believe.
Hence I reopened this issue.
Illya
AthiraM_Intel
AthiraM_Intel
We have not heard back from you. Could you please give us an update? Is your issue resolved?
AthiraM_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
