Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1296 Discussions
I can´t conected to devcloud by ssh
ruma
Hello everyone!!!
I can´t conected me to devcloud by ssh, Yesterday I saw the next message about it, when I try to work with devcloud.
ssh devcloud
 WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
Someone could be eavesdropping on you right now (man-in-the-middle attack)!
It is also possible that a host key has just been changed.
The fingerprint for the ECDSA key sent by the remote host is
Please contact your system administrator.
Add correct host key in /home/-----/.ssh/known_hosts to get rid of this message.
Offending ECDSA key in /home/------/.ssh/known_hosts:---
remove with:
ECDSA host key for ssh.devcloud.intel.com has changed and you have requested strict checking.
Host key verification failed.
kex_exchange_identification: Connection closed by remote host
Do you have to solved about this?
Regards.-
Ruma
AlekhyaV_Intel
Thank you for posting in Intel Communities. We sincerely apologize for the inconvenience caused. DevCloud was down from past two days. You can try the below steps to re-connect to devcloud again.
1) Download the new key from this link: https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-linux-macos/
2) Move/Copy this file to ~/.ssh folder & rename it to "devcloud-access-key-xxxxx.txt"
3) Give permissions to the file/folder as below:
chmod 600 ~/.ssh/devcloud-access-key-xxxxx.txt
chmod 600 ~/.ssh/config
(Ignore this step if you're connecting through Mobaxterm. This step is required only for Cygwin.
If this resolves your issue, please accept this as a solution as it might help others with the similar issue. Thanks in advance. Please let us know if this issue still persists.
Alekhya
AlekhyaV_Intel
Hi @ruma ,
We got to know that you've approached customer care that you are facing a new issue(Permission denied (publickey)" error. Sincere apologies for the inconvenience caused.
Unfortunately, While devcloud has migrated to a new SSH server, some users are facing this key issue. We are looking into this issue. We will connect with you via private message/email.
Alekhya
AlekhyaV_Intel
Thank you for sharing the DevCloud user ID with us. Is your issue resolved? If not, can you try this method(https://community.intel.com/t5/Intel-DevCloud/Announcement-Changes-to-SSH-Server-on-DevCloud/m-p/1394912#M5072) Please send us an update.
Alekhya
nka
I am also facing the issue. I completely removed all ssh configurations including the key and set everything up again with the setup script. Unfortunately the key is rejected as well:
guest@ssh.devcloud.intel.com: Permission denied (publickey).
Connection closed by UNKNOWN port 65535
I checked in the ssh config file that it is directing to ssh.devcloud.intel.com
Best wishes
Niklas
AlekhyaV_Intel
Hi @nka ,
Please post a new thread so that we can look into your issue separately.
Alekhya
nka
Hi Alekhya,
I tried again today and it is fixed. So no further investigations necessary.
Best wishes
Niklas
AlekhyaV_Intel
Hi @ruma ,
Is the issue resolved? Could you please give us an update regarding this issue?
Alekhya
AlekhyaV_Intel
We assume that your issue is resolved. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
