I was successfully connected to DevCloud through Cygwin (under win10)
But I cannot adjust WinSCP for an exchange of files with my source code and results of calculation
Whether it is possible to help with adjustment WinSCP?
YNS
Thanks for posting in Intel forums.
In cygwin you can use scp command, which is a very simple method to transfer files.
Just give the below command to transfer files
1)To Desktop
scp devcloud:/home/u*****/<directory or file> /home/<user>
2)To Devcloud
scp -r /home/<user>/<directory or file> devcloud:/home/u*****
Also you can directly download the files from jupyterlab.But WinSCP with Cygwin might not be possible.
Janani Chandran
Hi, Janani Chandran.
It is all works,
thanks you very much!
YNS
Thanks for the confirmation .If you need any additional information, please submit a new question as this thread will no longer be monitored.
Janani Chandran
