Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
I got a system without iGPU
Hariharasu_V_Intel
Hi, I got a system to test some programs with open MP offload and I need a iGPU/GPU to test the offload results.
I do not have a igpu in the current system I am using. How to upgrade or change it?
Thank you,
Hari
ArunJ_Intel
Hi Hari,
If you  need to request a compute node with igpu in interactive mode  use the below command (execute the command from the login node).
qsub -I -l nodes=1:gpu:ppn=2
Arun Jose
ArunJ_Intel
Hi Hari,
Hope your issue is resolved. Could you please confirm so we can close this case.
Arun Jose
ArunJ_Intel
Hi Hari,
We are closing this thread assuming the solution provided helps. Please raise a new thread if you are facing further issues.
Arun Jose
