Hi, I got a system to test some programs with open MP offload and I need a iGPU/GPU to test the offload results.
I do not have a igpu in the current system I am using. How to upgrade or change it?
Thank you,
Hari
- Tags:
- General Support
Hi Hari,
If you need to request a compute node with igpu in interactive mode use the below command (execute the command from the login node).
qsub -I -l nodes=1:gpu:ppn=2
Arun Jose
Hi Hari,
Hope your issue is resolved. Could you please confirm so we can close this case.
Arun Jose
Hi Hari,
We are closing this thread assuming the solution provided helps. Please raise a new thread if you are facing further issues.
Arun Jose
