I'm getting an almost immediate logout of an interactive job. (within less than a minute) It makes using the DevCloud impossible.
uXXXXX@login-2:~$ qsub -lnodes=1:gpu -lwalltime=02:00:00 -d. -I
qsub: waiting for job 490970.v-qsvr-1.aidevcloud to start
qsub: job 490970.v-qsvr-1.aidevcloud ready
# Date: Thu Feb 13 11:32:39 PST 2020
# Job ID: 490970.v-qsvr-1.aidevcloud
# User: uXXXXX
# Resources: neednodes=1:gpu,nodes=1:gpu,walltime=02:00:00
uXXXXX@s001-n141:~$ qstat
Job ID Name User Time Use S Queue
490970.v-qsvr-1 STDIN uXXXXX 0 R batch
uXXXXX@s001-n141:~$ qstat -l -f
Job Id: 490970.v-qsvr-1.aidevcloud
Job_Name = STDIN
Job_Owner = uXXXXX@login-2.aidevcloud
job_state = R
queue = batch
server = v-qsvr-1.aidevcloud
Checkpoint = u
ctime = Thu Feb 13 11:32:37 2020
Error_Path = /dev/pts/0
exec_host = s001-n141/0
Hold_Types = n
interactive = True
Join_Path = n
Keep_Files = n
Mail_Points = n
mtime = Thu Feb 13 11:32:39 2020
Output_Path = /dev/pts/0
Priority = 0
qtime = Thu Feb 13 11:32:37 2020
Rerunable = False
Resource_List.nodect = 1
Resource_List.nodes = 1:gpu
Resource_List.walltime = 02:00:00
session_id = 9193
Variable_List = PBS_O_QUEUE=batch,PBS_O_HOME=/home/uXXXXX,
PBS_O_LOGNAME=uXXXXX,
PBS_O_PATH=/glob/development-tools/versions/intel-parallel-studio/com
pilers_and_libraries_2019.3.199/linux/bin/intel64:/glob/development-to
ols/versions/intel-parallel-studio/compilers_and_libraries_2019.3.199/
linux/mpi/intel64/libfabric/bin:/glob/development-tools/versions/intel
-parallel-studio/compilers_and_libraries_2019.3.199/linux/mpi/intel64/
bin:/glob/development-tools/versions/intel-parallel-studio/debugger_20
19/gdb/intel64/bin:/glob/intel-python/python3/bin/:/glob/intel-python/
python2/bin/:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/
bin:/usr/games:/usr/local/games:/home/uXXXXX/.local/bin:/home/uXXXXX/b
in:/bin,PBS_O_MAIL=/var/mail/uXXXXX,PBS_O_SHELL=/bin/bash,
PBS_O_LANG=en_US,
PBS_O_SUBMIT_FILTER=/usr/local/sbin/torque_submitfilter,
PBS_O_INITDIR=/home/uXXXXX/.,PBS_O_WORKDIR=/home/uXXXXX,
PBS_O_HOST=login-2.aidevcloud,PBS_O_SERVER=v-qsvr-1.aidevcloud
euser = uXXXXX
egroup = uXXXXX
queue_type = E
etime = Thu Feb 13 11:32:37 2020
submit_args = -lnodes=1:gpu -lwalltime=02:00:00 -d. -I
start_time = Thu Feb 13 11:32:39 2020
Walltime.Remaining = 7187
start_count = 1
fault_tolerant = False
job_radix = 0
submit_host = login-2.aidevcloud
- Tags:
- General Support
Could you please try to login into gpu node using the below command and see if the issue still persists:
qsub -I -l nodes=1:gpu:ppn=2 -d.
You can also request a specific node using the below command
qsub -I -l nodes=s001-n208:gpu:ppn=2 -d.
The list of the nodes with GPU can be obtained by the next command:
pbsnodes | grep -B4 "gen9"
Hope this helps. If you face any further issue, please let us know.
Thanks, specifying ppn=2 prevents the logout. Seems odd that ppn is required on an interactive login session. I'm not sure how to interpret that parameter under this condition.
kevin
Glad to know that your issue got resolved.
In the above command, ppn=2 would request 2 processors on one node.
Please refer the below link for more details on job submission.
http://docs.adaptivecomputing.com/torque/3-0-5/2.1jobsubmission.php
Could you please confirm whether the solution provided was helpful.
Yes, setting ppn=2 prevents the logout and i can use the compute node normally.
kevin
Thanks for your confirmation.
We are closing this thread. Please feel free to open a new thread if you have any further queries.
