Hi Everyone,
I've recently created an account and I was trying the hello world program.
However, when I try to clone the github repo from the server I encounter this error:
$git clone https://github.com/oneapi-src/oneAPI-samples.git
Cloning into 'oneAPI-samples'...
fatal: unable to access 'https://github.com/oneapi-src/oneAPI-samples.git/': Could not resolve host: github.com
Should I do something to configure the server in addition to what specified in the guide?
Thank you.
Lorenzo
Good day to you.
Intel DevCloud does not allow external website access from the login node. It is only allowed inside compute nodes.
Login nodes use a lightweight general-purpose processor. Login nodes should not be used for development or execution of programs. It is an interface node that helps to connect or submit jobs to the compute nodes.
You can use wget/git clone/etc. on compute nodes only. You cannot use them on login node. However, the downloaded files would be available in the cloud, so you can access them in login node and compute node once downloaded.
From the above diagram, we could see that HTTPS cannot be accessed via login node.
You can use the command format below to request access to an interactive compute node from the login node:
$ qsub -I -l nodes=1:[property]:ppn=2 -d .
Eg:
qsub -I -l nodes=1:ppn=2 -d .
Refer documentation for more information: https://devcloud.intel.com/oneapi/documentation/job-submission/#accessing-compute-nodes
If this clarifies your query, make sure to accept this as a solution. This would help others with similar queries.
Thanks and Regards,
Jyothis V James
Good day to you.
Eg:
Thanks and Regards,
Jyothis V James
Thank you for the answer. This clarify the issue.
I would like to suggest to add this information to the page https://devcloud.intel.com/oneapi/get_started/hpcToolkitSamples/ under the run "Run a Hello World! Sample" since for a new user it may not be clear.
Lorenzo
Good day to you.
Glad to know that your issue is resolved. Thank you for your feedback. We have provided your feedback to the relevant team.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jyothis V James
