While importing certain packages like requests works just fine, how do I install and use seaborn? How can I use cell magic to display plots inline?
The following fails for me:
!pip install -U seaborn
import matplotlib.pyplot as plt
import seaborn as sns
Python cannot find seaborn. Similarly %matplotlib inline also fails. What can I use as a workaround?
The error might be due to when we use ! in front of a Linux command, it will start a new terminal each time, so in this terminal your environment is not activated.
You can follow any of the below workarounds provided.
Method 1: Start a Jupyter cell by using bash magic(%%bash). Now, export the correct python path and install the package.
Commands to be executed in the cell:-
%%bash
export PATH=/<python path>/:$PATH
pip install seaborn --user
pip install matplotlib --user
Method 2: Install the package from terminal
Step 1: Initialize the oneAPI environment
source /opt/intel/inteloneapi/setvars.sh
Step 2 : Activate the environment
conda activate <environment>
Step 3: Install seaborn and matplotlib in the environment
Now, open the Jupyterlab on your browser and start the kernel.
Hopes this will resolve your issue.
If the issue still persists please let us know, also share the error screenshots.
when i am trying to install tensorflow using "pip install tensorflow --user" command it fails and shows error at the end like shown below
memory error :Please visit the forums at: https://software.intel.com/en-us/forums/intel-devcloud blah blah
How to fix this
Could you please give us an update? Is your issue resolved?
We have not heard back from you, we would discontinue monitoring this issue. If you need further assistance, please post a new thread.
