On first login and all following logins to the Intel DevCloud bridge/login node I get the following message:
Process exceeded login node resource limit.
Please run jobs on compute nodes using qsub or start an interactive shell using qsub -I.
Please visit the forums at: https://software.intel.com/en-us/forums/intel-devcloud
There are/should be no processes running and the account was provisioned yesterday.
Is this a regular behavior(this message does not limit any account behavior).
Mark
This warning may be displayed intermittently and can be ignored. We have seen that this issue is fixed and does not occur now.
Yes, this is a regular behavior. This does not limit any functionality.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
Thasneem Vazim
Thasneem Vazim
I can confirm that the error message no longer shows up.
Thanks for confirming the same and accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thasneem Vazim
