Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1690 Discussions
Intel Developer Cloud Beta Password
computera13
I create ssh key with this method
mkdir %USERPROFILE%\.ssh
ssh-keygen -t ed25519 -f %USERPROFILE%\.ssh\id_rsa 
But when connect to instance type this command in cmd ssh -J guest@146.152.226.46 -L 10022:10.3.147.109:22 ubuntu@10.3.147.109 show Are you sure you want to continue connecting (yes/no/[fingerprint])? and I type yes then show this (guest@146.152.226.46) Password:
how get password?
Hairul_Intel
Hi computera13,
If you're using a Bare Metal Instance, you'd need to create a new SSH key by following Step 2. Setup - SH Keys and add it into your existing Bare Metal Instance by following the steps in Step 11.11 in Access a Bare Metal Instance.
On another note, if you're using free Tiny Virtual Machine instance, you'd need to create a new SSH Key, terminate the current instance and request a new Tiny Virtual Machine instance. Then, you should be able to launch the Virtual Machine instance straight to the welcome screen without needing any password.
Hairul
