Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1693 Discussions
Intel Developer Cloud for the Edge - compile_tool available with OpenVINO inside DevCloud?
JayBurris
Is the compile_tool available with OpenVINO on the Intel Developer Cloud for the Edge?
If so how does one access and use it?
Is there a code snippet for using the compile_tool?
https://docs.openvino.ai/latest/openvino_inference_engine_tools_compile_tool_README.html
JesusE_Intel
Hi JayBurris,
Thanks for reaching out! Compile tool is not available in the Jupyter Notebook environment as it is using OpenVINO from PyPI package (openvino and openvino-dev) and compile tool is not part of these packages.
However, you can use the compile tool by launching a Terminal (Jupyter Notebook Launcher -> Terminal (top right)) and run the following commands.
$ source /opt/intel/openvino_2022/setupvars.sh
[setupvars.sh] OpenVINO environment initialized
$ /opt/intel/openvino_2022/tools/compile_tool/compile_tool
OpenVINO Runtime version ......... 2022.1.0
Build ........... 2022.1.0-7019-cdb9bec7210-releases/2022/1
Path to model xml file is required
Please let me know if this works for you.
Jesus
JesusE_Intel
Hi JayBurris,
Jesus
JesusE_Intel
