Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1641 Discussions
Intel MKL FATAL ERROR: Cannot load libmkl_avx512.so or libmkl_def.so.
virtualdvid
Innovator
I'm getting this error:
It seems it is numpy issue but updating the library is not working.
ChithraJ_Intel
Could you please try out the below steps.
Step 1: Create a conda environment and activate the environment as
conda create -n env_face -c intel python=3.6
source activate env_face
Step 2: Uninstall the existing numpy package
pip uninstall numpy
Step 3: Install intel-numpy using pip
pip install intel-numpy
Now, in python shell, import the face_recognition package
python
import face_recognition
Hope it will resolve your issue.
ChithraJ_Intel
Could you please let us know the steps you have followed.
Kindly attach the screenshots, so that we can try it from our end.
virtualdvid
Innovator
Sure!
Steps:
  1. qsub -I        (to start a job)
  2. conda create -n my_env python=3.5 -y
  3. conda activate my_env
  4. pip install face_recognition --user        (I used the `user` flag since I was getting a user error see bellow)
  5. python
  6. import face_recognition
  7. error
I found the libraries in several places:
# export LD_LIBRARY_PATH=/glob/intel-python/versions/2018u2/intelpython3/lib:${LD_LIBRARY_PATH}
# export LD_LIBRARY_PATH=/glob/intel-python/versions/2019u1/intelpython3/lib:${LD_LIBRARY_PATH}
# export LD_LIBRARY_PATH=/glob/intel-python/versions/2019u2/intelpython3/lib:${LD_LIBRARY_PATH}
# export LD_LIBRARY_PATH=/glob/intel-python/versions/2019u3/intelpython3/lib:$LD_LIBRARY_PATH
export LD_LIBRARY_PATH=/home/u14913/.conda/envs/face/lib/:$LD_LIBRARY_PATH
also did:
export LD_PRELOAD=/home/u14913/.conda/envs/face/lib/libmkl_avx512.so python -c 'import face_recognition'
also followed this post: anaconda mkl
Nothing worked so far
#      Date:           Mon Jan 13 23:48:37 PST 2020
#    Job ID:           463052.v-qsvr-1.aidevcloud
#      User:           uXXXXX
# Resources:           neednodes=1:batch:ppn=2,nodes=1:batch:ppn=2,walltime=06:00:00
(base) uXXXXX@s001-n105:~$ conda activate my_env
(my_env) uXXXXX@s001-n105:~$ python
Python 3.6.3 |Intel Corporation| (default, Feb 12 2018, 06:37:09)
[GCC 4.8.2 20140120 (Red Hat 4.8.2-15)] on linux
Type "help", "copyright", "credits" or "license" for more information.
Intel(R) Distribution for Python is brought to you by Intel Corporation.
Please check out: https://software.intel.com/en-us/python-distribution
(my_env) u14913@s001-n105:~$
#### User error #####
(my_env) uXXXXX@s001-n105:~$ pip install face_recognition
Collecting face_recognition
  Using cached https://files.pythonhosted.org/packages/3f/ed/ad9a28042f373d4633fc8b49109b623597d6f193d3bbbef7780a5ee8eef2/face_recognition-1.2.3-py2.py3-none-any.whl
Collecting Click>=6.0 (from face_recognition)
  Using cached https://files.pythonhosted.org/packages/fa/37/45185cb5abbc30d7257104c434fe0b07e5a195a6847506c074527aa599ec/Click-7.0-py2.py3-none-any.whl
Collecting numpy (from face_recognition)
  Using cached https://files.pythonhosted.org/packages/62/20/4d43e141b5bc426ba38274933ef8e76e85c7adea2c321ecf9ebf7421cedf/numpy-1.18.1-cp36-cp36m-manylinux1_x86_64.whl
Collecting my_env-recognition-models>=0.3.0 (from face_recognition)
Collecting Pillow (from face_recognition)
  Using cached https://files.pythonhosted.org/packages/19/5e/23dcc0ce3cc2abe92efd3cd61d764bee6ccdf1b667a1fb566f45dc249953/Pillow-7.0.0-cp36-cp36m-manylinux1_x86_64.whl
Collecting dlib>=19.7 (from face_recognition)
Installing collected packages: Click, numpy, my_env-recognition-models, Pillow, dlib, my_env-recognition
Exception:
  File "/home/uXXXXX/.local/lib/python3.6/site-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/home/uXXXXX/.local/lib/python3.6/site-packages/pip/commands/install.py", line 342, in run
    prefix=options.prefix_path,
  File "/home/uXXXXX/.local/lib/python3.6/site-packages/pip/req/req_set.py", line 784, in install
    **kwargs
  File "/home/uXXXXX/.local/lib/python3.6/site-packages/pip/req/req_install.py", line 851, in install
    self.move_wheel_files(self.source_dir, root=root, prefix=prefix)
  File "/home/uXXXXX/.local/lib/python3.6/site-packages/pip/req/req_install.py", line 1064, in move_wheel_files
    isolated=self.isolated,
  File "/home/uXXXXX/.local/lib/python3.6/site-packages/pip/wheel.py", line 345, in move_wheel_files
    clobber(source, lib_dir, True)
  File "/home/uXXXXX/.local/lib/python3.6/site-packages/pip/wheel.py", line 316, in clobber
    ensure_dir(destdir)
  File "/home/uXXXXX/.local/lib/python3.6/site-packages/pip/utils/__init__.py", line 83, in ensure_dir
    os.makedirs(path)
  File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/os.py", line 220, in makedirs
    mkdir(name, mode)
OSError: [Errno 30] Read-only file system: '/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/click'
You are using pip version 9.0.1, however version 19.3.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
Please use "pip install --user <package>" to install user packages.
Please visit the forums at: https://software.intel.com/en-us/forums/intel-devcloud
ChithraJ_Intel
We are also able to reproduce your issue.
We are working on it and let you know the updates later.
ChithraJ_Intel
pip uninstall numpy
python
virtualdvid
Innovator
There we go, it worked. Thank you!
ChithraJ_Intel
Thanks for the confirmation.We are closing the case.
Please feel free to raise a new thread in case if you face any further issues.
