I'm getting this error:
Intel MKL FATAL ERROR: Cannot load libmkl_avx512.so or libmkl_def.so.
It seems it is numpy issue but updating the library is not working.
- Tags:
- General Support
Could you please try out the below steps.
Step 1: Create a conda environment and activate the environment as
conda create -n env_face -c intel python=3.6 source activate env_face
Step 2: Uninstall the existing numpy package
pip uninstall numpy
Step 3: Install intel-numpy using pip
pip install intel-numpy
Now, in python shell, import the face_recognition package
python import face_recognition
Hope it will resolve your issue.
Could you please let us know the steps you have followed.
Kindly attach the screenshots, so that we can try it from our end.
Sure!
Steps:
- qsub -I (to start a job)
- conda create -n my_env python=3.5 -y
- conda activate my_env
- pip install face_recognition --user (I used the `user` flag since I was getting a user error see bellow)
- python
- import face_recognition
- error
I found the libraries in several places:
# export LD_LIBRARY_PATH=/glob/intel-python/versions/2018u2/intelpython3/lib:${LD_LIBRARY_PATH}
# export LD_LIBRARY_PATH=/glob/intel-python/versions/2019u1/intelpython3/lib:${LD_LIBRARY_PATH}
# export LD_LIBRARY_PATH=/glob/intel-python/versions/2019u2/intelpython3/lib:${LD_LIBRARY_PATH}
# export LD_LIBRARY_PATH=/glob/intel-python/versions/2019u3/intelpython3/lib:$LD_LIBRARY_PATH
export LD_LIBRARY_PATH=/home/u14913/.conda/envs/face/lib/:$LD_LIBRARY_PATH
also did:
export LD_PRELOAD=/home/u14913/.conda/envs/face/lib/libmkl_avx512.so python -c 'import face_recognition'
also followed this post: anaconda mkl
Nothing worked so far
######################################################################## # Date: Mon Jan 13 23:48:37 PST 2020 # Job ID: 463052.v-qsvr-1.aidevcloud # User: uXXXXX # Resources: neednodes=1:batch:ppn=2,nodes=1:batch:ppn=2,walltime=06:00:00 ######################################################################## (base) uXXXXX@s001-n105:~$ conda activate my_env (my_env) uXXXXX@s001-n105:~$ python Python 3.6.3 |Intel Corporation| (default, Feb 12 2018, 06:37:09) [GCC 4.8.2 20140120 (Red Hat 4.8.2-15)] on linux Type "help", "copyright", "credits" or "license" for more information. Intel(R) Distribution for Python is brought to you by Intel Corporation. Please check out: https://software.intel.com/en-us/python-distribution >>> import face_recognition Intel MKL FATAL ERROR: Cannot load libmkl_avx512.so or libmkl_def.so. (my_env) u14913@s001-n105:~$
#### User error #####
(my_env) uXXXXX@s001-n105:~$ pip install face_recognition Collecting face_recognition Using cached https://files.pythonhosted.org/packages/3f/ed/ad9a28042f373d4633fc8b49109b623597d6f193d3bbbef7780a5e... Collecting Click>=6.0 (from face_recognition) Using cached https://files.pythonhosted.org/packages/fa/37/45185cb5abbc30d7257104c434fe0b07e5a195a6847506c074527a... Collecting numpy (from face_recognition) Using cached https://files.pythonhosted.org/packages/62/20/4d43e141b5bc426ba38274933ef8e76e85c7adea2c321ecf9ebf74... Collecting my_env-recognition-models>=0.3.0 (from face_recognition) Collecting Pillow (from face_recognition) Using cached https://files.pythonhosted.org/packages/19/5e/23dcc0ce3cc2abe92efd3cd61d764bee6ccdf1b667a1fb566f45dc... Collecting dlib>=19.7 (from face_recognition) Installing collected packages: Click, numpy, my_env-recognition-models, Pillow, dlib, my_env-recognition Exception: Traceback (most recent call last): File "/home/uXXXXX/.local/lib/python3.6/site-packages/pip/basecommand.py", line 215, in main status = self.run(options, args) File "/home/uXXXXX/.local/lib/python3.6/site-packages/pip/commands/install.py", line 342, in run prefix=options.prefix_path, File "/home/uXXXXX/.local/lib/python3.6/site-packages/pip/req/req_set.py", line 784, in install **kwargs File "/home/uXXXXX/.local/lib/python3.6/site-packages/pip/req/req_install.py", line 851, in install self.move_wheel_files(self.source_dir, root=root, prefix=prefix) File "/home/uXXXXX/.local/lib/python3.6/site-packages/pip/req/req_install.py", line 1064, in move_wheel_files isolated=self.isolated, File "/home/uXXXXX/.local/lib/python3.6/site-packages/pip/wheel.py", line 345, in move_wheel_files clobber(source, lib_dir, True) File "/home/uXXXXX/.local/lib/python3.6/site-packages/pip/wheel.py", line 316, in clobber ensure_dir(destdir) File "/home/uXXXXX/.local/lib/python3.6/site-packages/pip/utils/__init__.py", line 83, in ensure_dir os.makedirs(path) File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/os.py", line 220, in makedirs mkdir(name, mode) OSError: [Errno 30] Read-only file system: '/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/click' You are using pip version 9.0.1, however version 19.3.1 is available. You should consider upgrading via the 'pip install --upgrade pip' command. Please use "pip install --user <package>" to install user packages. Please visit the forums at: https://software.intel.com/en-us/forums/intel-devcloud (my_env) uXXXXX@s001-n105:~$
We are also able to reproduce your issue.
We are working on it and let you know the updates later.
pip uninstall numpy
There we go, it worked. Thank you!
Thanks for the confirmation.We are closing the case.
Please feel free to raise a new thread in case if you face any further issues.
