Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1596 Discussions
Intel devcloud ssh connection error
Ra10
I have followed those steps here: https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-windows-cygwin/ but I keep getting connection time out errors when I do ssh devcloud or devcloud.proxy. I have tried to turn off VPN but I still cannot connect to devcloud.
Would it be possible to help me out with this ?
JaideepK_Intel
Thank you for posting in the intel communities.
Please follow the below steps for automated installation:
1. Download this simple Windows batch script https://devcloud.intel.com/oneapi/static/assets/install_cygwin.bat.
2. Extract the downloaded script (keep it as default c:\cygwin64)
3. Now open the Cygwin64 terminal, which looks like below.
4. Now go to the below path and add the setup-devcloud-access-xxxxxx.txt to that path.
path: C:\cygwin64\home\<User_name>
file: setup-devcloud-access-xxxxxx.txt
5. Open the Cygwin terminal and follow the below commands.
$ ls
$ bash ./setup-devcloud-access-xxxxxx.txt
6. Connect to the DevCloud using( ssh devcloud)
Connect to the DevCloud via proxy:
1. Before connecting via proxy, we need to modify the config file. config file is loacted in the below path
path:C:\cygwin64\home\<User_name>\.ssh
In the above path, open the config file and modify it as shown in the below pic.
add: nc -x proxy-us.intel.com %h %p (after ProxyCommand)
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you
Jaideep
JaideepK_Intel
$ ls
Jaideep
Ra10
Hi Jaideep,
These steps work perfectly. Thanks a lot for your help. Now, as I am running the hello world example here,  https://devcloud.intel.com/oneapi/get_started/baseToolkitSamples/
I get the following errors:
make: *** No rule to make target 'clean'. Stop.
make: *** No rule to make target 'all'. Stop.
Can you help me resolve this issue ?
JaideepK_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
