Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1660 Discussions
Interactive node with multiple properties
ffa
How to request node with multiple properties?
RemyaP_Intel
Thank you for posting in Intel communities.
You can request a node using multiple properties of it by mentioning the properties in the qsub command separated by a colon (:)
Example below:
qsub -I -l nodes=1:xeon:e-2176g:net1gbe:ppn=2
If this resolves your issue, make sure to accept this as a solution. This would help others with a similar issue. Thank you!
Remya Premdas
RemyaP_Intel
Example below:
Remya Premdas
RemyaP_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Remya Premdas
