Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1689 Discussions
Intruder Detector Sample Application not working with OpenVINO 2020.3.2 LTS
E-Hong
Hi, the default Intruder Detector Sample Application notebook is not able to connect to any of the available nodes. Please advice on this issue, is there any workaround for this?
Labels (2)
JesusE_Intel
Hi E-Hong,
You may be using the Intruder Detector Sample located in Reference-samples/iot-devcloud/openvino-dev-latest/developer-samples/python/intruder-detector-python/intruder-detector-jupyter.ipynb
For OpenVINO 2020.3.2 LTS release, try to use the notebook located under the LTS directory:
Reference-samples/iot-devcloud/openvino-lts/developer-samples/python/intruder-detector-python/intruder-detector-jupyter.ipynb
Jesus
JesusE_Intel
Hi E-Hong,
Jesus
JesusE_Intel
Hi E-Hong,
Just want to check if my previous suggestion worked for you. Also, there is a possibility we may be removing OpenVINO 2020.3.2 LTS version from Intel Developer Cloud for the Edge. Could you let me know if there is a need for this OpenVINO version or if you are okay using one of the other OpenVINO versions.
Jesus
E-Hong
Hi Jesus,
I am still trying out the one under "openvino-dev-latest" directory;
To your question on removing the LTS support from cloud, my only concern and need is the availability of Mustang F100 Arria 10 PAC, "iei-mustang-f100-a10" only. If the A10 PAC is accessbile and supported on other OpenVINO version, then it shall be all good with me.
Thank you.
E-Hong
JesusE_Intel
Thank you for the feedback! I will proceed to close this discussion. If you need any additional information, please submit a new question as this thread will no longer be monitored.
