Hi
When running SYCL programs (I assume this applies to any OpenCL program as well) on Iris Xe MAX nodes, the runtime doesn't seem to support doubles.
To reproduce:
> qsub -l nodes=1:iris_xe_max:ppn=2 -I
# once job started:
> git clone git@github.com:UoB-HPC/BabelStream.git
> cd BabelStream
> make -f SYCL.make COMPILER=DPCPP
> ./sycl-stream --list # compiled program is called sycl-stream
> ./sycl-stream --device 2 # pick Iris Xe GPU
The output is as follows:
BabelStream
Version: 3.4
Implementation: SYCL
Running kernels 100 times
Precision: double
Array size: 268.4 MB (=0.3 GB)
Total size: 805.3 MB (=0.8 GB)
Using SYCL device Intel(R) Graphics [0x4905]
Driver: 21.01.18793
Reduction kernel config: 384 groups of size 512
terminate called after throwing an instance of 'cl::sycl::compile_program_error'
what(): The program was built for 1 devices
Build program log for 'Intel(R) Graphics [0x4905]':
error: double type is not supported on this platform
error: backend compiler failed build.
-11 (CL_BUILD_PROGRAM_FAILURE)
Aborted
To confirm device capability, running `clinfo` yields the following:
Device Name Intel(R) Graphics [0x4905]
Device Vendor Intel(R) Corporation
Device Vendor ID 0x8086
Device Version OpenCL 3.0 NEO
Driver Version 21.01.18793
# -- snip --
Preferred / native vector sizes
char 16 / 16
short 8 / 8
int 4 / 4
long 1 / 1
half 8 / 8 (cl_khr_fp16)
float 1 / 1
double 1 / 1 (n/a)
Half-precision Floating-point support (cl_khr_fp16)
# -- snip --
Double-precision Floating-point support (n/a)
# -- snip --
This doesn't seem right, double precision is supported on gen9 nodes and I was able to run BabelStream correctly.
Perhaps the driver is outdated?
Please export the below environment variables before running the commands.
export OverrideDefaultFP64Settings=1
export IGC_EnableDPEmulation=1
If you face any further issue please let us know.
Could you please give us an update? Is your issue resolved?
We are assuming that the solution provided helped and would no longer be monitoring this issue. Please raise a new thread if you have further issues.
