Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1644 Discussions
Iris Xe MAX on DevCloud
Cielo__Salvatore
Hi all,
is it true that the new Xe GPUs are available on the DevCloud? I got the notification via email, and can't wait to test them for my computing kernels, but I couldn't find instructions on how to access them yet.
Thank you for any news!
Best,
JananiC_Intel
Thanks for posting in Intel forums.
Intel Iris Xe MAX GPU's are available in devcloud now.You can connect the node with any of the below commands.
qsub -I -l nodes=1:dual_gpu:ppn=2 (or) qsub -I -l nodes=1:quad_gpu:ppn=2
As of now documentation is not updated.We have informed the concerned team about this.
Hope this helps!
JananiC_Intel
Hope this helps!
Cielo__Salvatore
Thanks a lot, I could access it.
oneMKL code gets easily a speedup of 1.5x over a gen9, on some simple gemm test.
I could not yet run general sycl code (some USM parallel_for), that works on gen9.
I got the following problem:
The program was built for 1 devices
Build program log for 'Intel(R) Gen12LP':
-11 (CL_BUILD_PROGRAM_FAILURE)
terminate called after throwing an instance of 'cl::sycl::compile_program_error'
But no problem, I will wait for documentation.
Best,
JananiC_Intel
Thanks for the update.
Since your initial query is resolved,we would discontinue monitoring this issue.Please raise a new thread if you have further issues.
