Hi all,
is it true that the new Xe GPUs are available on the DevCloud? I got the notification via email, and can't wait to test them for my computing kernels, but I couldn't find instructions on how to access them yet.
Thank you for any news!
Best,
Thanks for posting in Intel forums.
Intel Iris Xe MAX GPU's are available in devcloud now.You can connect the node with any of the below commands.
qsub -I -l nodes=1:dual_gpu:ppn=2 (or) qsub -I -l nodes=1:quad_gpu:ppn=2
As of now documentation is not updated.We have informed the concerned team about this.
Hope this helps!
Hope this helps!
Thanks a lot, I could access it.
oneMKL code gets easily a speedup of 1.5x over a gen9, on some simple gemm test.
I could not yet run general sycl code (some USM parallel_for), that works on gen9.
I got the following problem:
The program was built for 1 devices
Build program log for 'Intel(R) Gen12LP':
-11 (CL_BUILD_PROGRAM_FAILURE)
terminate called after throwing an instance of 'cl::sycl::compile_program_error'
But no problem, I will wait for documentation.
Best,
Thanks for the update.
Since your initial query is resolved,we would discontinue monitoring this issue.Please raise a new thread if you have further issues.
