My dpc++ code segfaults. Surprise.
Is gdb or another commandline debugger available?
Regarding the segmentation fault, please make sure that you are trying the sample from compute node.
You can login to the compute node using the below command
qsub -I
If you are already in the compute node and facing the issue, please share the steps to reproduce the issue.
Regarding gdb, you can use gdb-oneapi which is pre-installed in DevCloud. You can use it by using the command
gdb-oneapi
If you are facing any issue, please let us know.
qsub -I
gdb-oneapi
We would discontinue monitoring this issue as the solution provided is accepted as the solution. Please raise a new thread if you have further issues.
