Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1592 Discussions
Is it possible to install byobu in the login nodes?
Juan_Fumero
When accessing to `login-1` node, sometimes my connection drops. I wonder if `byobu` or `screen` utils can be installed in the login nodes so, if the connection drops, I can have my session still active with all files I had opened.
Juan
JEYANTHKRI_N_Intel
We are sorry to inform you that the installation of byobu requires sudo access ,and the devcloud admin team wont provide sudo access to individual users as part of security concern.
Juan_Fumero
Hi JeyanthN,
   thank you for your quick reply. My question was if the admins could install that utility in the front-end and login nodes. I don't need/want sudo-access.
Juan
JEYANTHKRI_N_Intel
Hi ,
We understand your concern.Unfortunately, the Devcloud Admin team will not cater to requests to install packages at system level.
JEYANTHKRI_N_Intel
Hi ,
Could you please let us know if the solution provided helped?
