I am using Devcloud for FPGA, and when I check devcloud_login SNN, it says the Stratix 10 (not OneAPI) nodes are available, but when I submit the job, it cancels after a few seconds. I used the qsub command and it gives me this error:
qsub: submit error (Job exceeds queue resource limits MSG=cannot locate feasible nodes (nodes file is empty, all systems are busy, or no nodes have the requested feature))
I have not changed my job submission resource requirements so I do not expect resources to be an issue.
I checked the pbsnodes command and only the s001 and s002 nodes seem to show up. My guess is that the devices are available but the host CPUs for those devices are busy.
Thank you for posting in Intel Community.
We are able to reproduce your issue. We are checking on this internally, will let you know the updates soon.
