Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1517 Discussions
Job submitted to devcloud not running
risan-raja
Job submitted to devcloud not running. When I submit with a job using qsub <script>.sh it gets submitted and exits without output or stderr
FelipeML
Hi @JyothisV_Intel ,
I had the same problem.
I was trying to submit a Python code that only needs to use CPU and constantly the job finished without any output, while in interactive mode it worked perfectly. This was the script I was submitting with "qsub job.sh":
Testing I found that it was not a job submission problem because I was able to submit the simple examples in the guide. I started testing with more complex examples until I tried again with my python code again and now it worked. This was the script:
After this I was able to submit jobs without problems, as I was doing initially.
JyothisV_Intel
Good day to you.
From your query, we are not clear about the exact issue that you are facing. To assist you better, can you provide us with the following information:
  1. Are you using Intel DevCloud for oneAPI or Intel DevCloud for Edge or Intel DevCloud for FPGA?
  2. Can you provide us with a sample reproducer code and the exact steps that you followed to submit the job using qsub?
Jyothis V James
FelipeML
JyothisV_Intel
Hi @risan-raja,
Good day to you.
Glad to know that your issue is resolved. @FelipeML Thanks for sharing the solution with the community.
Intel DevCloud for oneAPI users is not allowed to execute programs in login node. To run code, it is recommended to use interactive node as per the documentation provided below:
Job Submission | Intel® DevCloud
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jyothis V James
