Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1642 Discussions
Locating the Result on FPGA in Intel DevCloud
rico22
Hi, everyone. I am learning OneAPI OpenCL FPGA implementation in the Intel DevCloud by following this link (https://github.com/intel/FPGA-Devcloud/tree/master/main/QuickStartGuides/OpenCL_Program_PAC_Quickstart/Arria%2010). I am working with MobaXterm on Windows OS. It's a simple 'Hello World' example. I completed every step and everything worked perfectly. It also said 'kernel execution is complete' at the end of the terminal. Now, I would like to see the 'Hello World' result. How am I able to see it in the Intel DevCloud? Thank you.
JaideepK_Intel
Good day to you.
To assist you further, can you confirm which Intel DevCloud you are using? Is it Intel DevCloud for oneAPI or Intel DevCloud for Edge or Intel DevCloud for FPGA?
Jaideep
JaideepK_Intel
Can you please share the above details? so that we can proceed further.
Jaideep
rico22
Hi, Jaideep. I am working on Intel DevCloud for oneAPI. Here's the link: https://devcloud.intel.com/oneapi/get_started/. Thank you.
JaideepK_Intel
Thank you for the confirmation.
As you mentioned, you were able to run the "Hello World" example, so there are going to be two output files generated. The output files look like the ones below.
job.sh.e.xxxx
job.sh.o.xxxx
The samples that you are using are from Devcloud for FPGA. Since you are using Devcloud for OneAPI, you need to use OneAPI samples.
OneAPI Vector Add sample: oneAPI-samples/DirectProgramming/DPC++/DenseLinearAlgebra/vector-add at master · oneapi-src/oneAPI-samples · GitHub
OneAPI DPC++ FPGA samples: oneAPI-samples/DirectProgramming/DPC++FPGA at master · oneapi-src/oneAPI-samples · GitHub
Jaideep
JaideepK_Intel
Good day to you.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
