Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1796 Discussions
Login error with devcloud
Mayank_K
I am trying to access the scheduled batch service of the instance Intel® Max Series GPU (PVC) on 4th Gen Intel® Xeon® processors - 1100 series (4x) as part of an Intel oneAPI center of excellence project. Following the method detailed in
github/bjodom/idc
Although I have precisely followed the steps I am getting the following error as I try to access the instance
mayank@DLSCD0055:~$ ssh u106717@idcbetabatch.eglb.intel.com
u106717@idcbetabatch.eglb.intel.com: Permission denied (publickey).
I am using WSL2 and the config file contents are as below.
Host myidc
Hostname idcbetabatch.eglb.intel.com
User u106717
IdentityFile ~/.ssh/id_ed25519_idc
#ProxyCommand /usr/bin/nc -x YourProxy:XXXX %h %p # Uncomment if necessary
ServerAliveInterval 60
ServerAliveCountMax 10
StrictHostKeyChecking no
UserKnownHostsFile=/dev/null
Kindly help me resolve the issue.
Mayank
Megat_Intel
Hi Mayank,
Thank you for reaching out to Intel® Communities.
For your information, the public key must be saved in the profile before starting an instance. The instance will need to be relaunched if the public key is updated after an instance is launched.
On the other hand, are you using any proxy for your internet connection? If not, please modify the config file (~/.ssh/config) as below and initiate the ssh again in a new terminal.
Host myidc
User u106717
Megat
Mayank_K
Hi Megat,
The issue is resolved and I am now able to access the Intel Devcloud. Thank you
Kind regards,
Mayank
Megat_Intel
Hi Mayank,
We're glad you are able to access the instance. This thread will no longer be monitored since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Megat
