A.
I am trying to do a distributed computing on two nodes using MPI and Julia as well as with the use of standalone Julia abilities.
I am able to do calculations on all 24 workers on one node in interactive and batch modes without any problems in pure Julia with
using Distributed
addprocs(24)
@everywhere ...
which is a basic functionality of Julia as described at [https://docs.julialang.org/en/v1/manual/distributed-computing/].
I am able to do basic MPI with the use of MPI.jl package [https://github.com/pressel/MPI.jl]:
using MPI
MPI.Init()
println("Hi from $(MPI.Comm_rank(MPI.COMM_WORLD))!")
flush(stdout)
mpirun -np 24 julia hello_world.jl.
However, I am not able to correctly add all 24 / 48 workers on two nodes. In theory I should be able to:
- add workers with the use of machine file when starting Julia
julia --machine-file=$PBS_NODEFILE
or
- with the use of MPIClustersManagers.jl [https://github.com/JuliaParallel/MPIClusterManagers.jl]
using Distributed
using MPIClusterManagers
# specify, number of mpi workers
manager=MPIManager(np=48)
# start mpi workers and add them as julia workers too.
addprocs(manager)
@everywhere import MPI
sleep(60.000) # provide time for workers to start
#Setup the worker environments
@everywhere using PackageName
#Solve with
@MPi_do manager begin
using MPI
experiment = Examples.experiments["name_of_experiment"]
session = Session(experiment, dir="/home/uxxxxx/data/xxxxx/xxxxx.jl/mytrainings/sessions/name_of_experiment")
resume!(session)
end
I have done a significant number of tries with different combinations described at various discussion lists, however I am unable to correctly launch workers on two nodes. The most common errors I see are as follow:
ERROR: TaskFailedException
nested task error: Unable to read host:port string from worker. Launch command exited with error?
caused by: Unable to read host:port string from worker. Launch command exited with error?
or/and
sh: 7: /etc/profile.d/add-local-path.sh: Syntax error: redirection unexpected
or
[mpiexec@s001-n047] HYD_hostfile_parse (../../../../../src/pm/i_hydra/libhydra/hostfile/hydra_hostfile.c:69): unable to open host file: -n
[mpiexec@s001-n047] mfile_fn (../../../../../src/pm/i_hydra/mpiexec/mpiexec_params.c:489): error parsing hostfile
[mpiexec@s001-n047] match_arg (../../../../../src/pm/i_hydra/libhydra/arg/hydra_arg.c:83): match handler returned error
[mpiexec@s001-n047] HYD_arg_parse_array (../../../../../src/pm/i_hydra/libhydra/arg/hydra_arg.c:128): argument matching returned error
[mpiexec@s001-n047] mpiexec_get_parameters (../../../../../src/pm/i_hydra/mpiexec/mpiexec_params.c:1356): error parsing input array
[mpiexec@s001-n047] main (../../../../../src/pm/i_hydra/mpiexec/mpiexec.c:1749): error parsing parameters
or
IOError: could not spawn setenv(`/home/uxxxxx/packages/julias/julia-1.6.1/bin/julia -Cnative -J/home/u77446/packages/julias/julia-1.6.1/lib/julia/sys.so -g1 --bind-to 127.0.0.1 --worker`; dir="/home/uxxxxx/data/xxxxx/xxxxx/mytrainings"): resource temporarily unavailable (EAGAIN)
Thus I would like to ask if any guidance from you on this topic would be possible. I would really appreciate any information.
B.
Also, heaving the opportunity, I would like to ask a question about gnome-terminal at renderkit machine. It used to work ok, however recently it does not want to start anymore. I tracked the error:
Error constructing proxy for org.gnome.Terminal:/org/gnome/Terminal/Factory0: Error calling StartServiceByName for org.gnome.Terminal: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.gnome.Terminal exited with status 8
I guess that the error is associated with broken Locale. Also the machine asks for a reboot.
To get the terminal working I have to execute LC_ALL=en_US.UTF-8 /usr/bin/dbus-launch gnome-terminal in XTerm.
Would it be possible to receive some guidance on this topic?
SZ
Thanks for posting in Intel forums. We are checking on this issue from our side. We will get back to you.
Rahul
Thanks Rahul. One information that I think might be relevant and I would like to add is that I understand that in contrary to MPI, Julia is not natively supported here, however, what I am trying to do currently is to transform a quite extensive machine / reinforcement learning model (package) in a way that it would be able to utilize oneAPI and corresponding Intel software and hardware technologies. I understand that this kind of activities might be / is in line with Devcloud's policy thus those kind of questions. SZ
We are working on it and will get back to you soon.
Thanks & Regards
Shivani
Hi!
Thanks. I'll really appreciate any information on this topic, especially about distributed computing. Also a very general, even preliminary information / assumption if it is doable at all or not would be useful.
SZ
Hello - thank you for your message. I will begin an investigation into this.
Hello. Thank you. Should you have any additional questions or may I be in any help please let me know.
Hello- For part B of this issue it would be best to post a thread in Render toolkit forum at
https://community.intel.com/t5/Intel-oneAPI-Rendering-Toolkit/bd-p/oneapi-rendering-toolkit
For part A- compile one of the test programs without Julia in $I_MPI_ROOT/test and run it with the same job layout with Julia. If that fails please repeat it I_MPI_DEBUG=16 and attach the log.
Re: part B:
Thank you. I will.
Re: part A:
Thank you. Sure, I will compile test programs and I'll try to do tests in Julia. Please be advised that during this week I might spend less time at Devcloud than usual, however, please be assured that I will reply soon.
SZ
