When I was trying to compile a large project. The compiler indicated that
cc1plus: out of memory allocating 65536 bytes after a total of 36966400 bytes
However, I checked the memory usage and there is free memory.
Then I checked the limitation with the command ulimit -a
I found the memory limitation of a single thread is set to 1GB.
I wish if there's any way to remove the limitation.
I didn't enter the computation node.
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Remya Premdas
