I am trying to run OpenCL applications on Devcloud FPGA nodes, it seems FCD entry is missing for nodes 81-87
aocl diagnose command returns following:
ICD System Diagnostics
--------------------------------------------------------------------Using the following location for ICD installation:
/etc/OpenCL/vendorsFound 4 icd entry at that location:
/etc/OpenCL/vendors/Altera.icd
/etc/OpenCL/vendors/intel-cpu.icd
/etc/OpenCL/vendors/intel-neo.icd
/etc/OpenCL/vendors/Intel_FPGA_SSG_Emulator.icdThe following OpenCL libraries are referenced in the icd files:
libalteracl.so
libintelocl.so
libigdrcl.so
libintelocl_emu.soChecking LD_LIBRARY_PATH for registered libraries:
libalteracl.so was registered on the system at /opt/intel/inteloneapi/compiler/2021.1-beta04/linux/lib/oclfpga/host/linux64/lib
libintelocl.so was registered on the system at /opt/intel/inteloneapi/compiler/latest/linux/lib/x64
WARNING: libigdrcl.so NOT FOUND
libintelocl_emu.so was registered on the system at /opt/intel/inteloneapi/compiler/2021.1-beta04/linux/lib/oclfpga/host/linux64/lib
/opt/intel/inteloneapi/compiler/latest/linux/lib/x64/libintelocl.so was registered on the system.Using the following location for fcd installations:
/opt/Intel/OpenCLFPGA/oneAPI/BoardsERROR: No FCD entry at that location. Without ICD and FCD, host executables
must be linked directly to Intel FPGA runtime (libalteracl.so) and BSP MMD
library instead of to the Khronos ICD library (libOpenCL.so).
To use FCD, please reinstall using 'aocl install'.
ICD diagnostics FAILED
BSP Diagnostics
/opt/intel/inteloneapi/compiler/2021.1-beta04/linux/lib/oclfpga/board/intel_a10gx_pac/linux64/libexec/diagnose: error while loading shared libraries: libopae-c.so.1: cannot open shared object file: No such file or directory
Warning:
No devices attached for package:
--------------------------------------------------------------------Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devices
- Tags:
- General Support
FPGA issues are not handled here. Please ask your question in the https://forums.intel.com/s/topic/0TO0P0000001AUUWA2/intel-high-level-design?language=en_US Forum.
