Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1521 Discussions
Not able to connect to edge server
Sundarrajan_G
I have registered but not able to start my server. It returns below error even after launching several times. Please help.
500 : Internal Server Error
Error in Authenticator.pre_spawn_start: RuntimeError socket_connect_unix failed: 15137 socket_connect_unix failed: 15137 socket_connect_unix failed: 15137 qstat: cannot connect to server (null) (errno=15137) could not connect to trqauthd qstat: Error (15137 - could not connect to trqauthd)
You can try restarting your server from the home page.
JesusE_Intel
Hi Sundarrajan_G,
Thank you for reporting, we have addressed the issue. Please try again and let me know if you are unable to access the server.
Jesus
JesusE_Intel
Hi Sundarrajan_G,
Jesus
Sundarrajan_G
Thanks Jesus. Problem is solved.
JesusE_Intel
Hi Sundarrajan_G,
Thank you for confirming, feel free to start a new discussion if you run into additional issues as Intel will no longer monitor this thread.
Jesus
