used
pip install seaborn --user
got the following error message
u38476@s001-n061:~$ pip install seaborn --user
File "/glob/intel-python/python3/bin/pip", line 4, in <module>
import pip
File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/__init__.py", line 26, in <module>
from pip.utils import get_installed_distributions, get_prog
File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/utils/__init__.py", line 27, in <module>
from pip._vendor import pkg_resources
File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/_vendor/pkg_resources/__init__.py", line 3018, in <module>
@_call_aside
File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/_vendor/pkg_resources/__init__.py", line 3004, in _call_aside
f(*args, **kwargs)
File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/_vendor/pkg_resources/__init__.py", line 3046, in _initialize_master_working_set
dist.activate(replace=False)
File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/_vendor/pkg_resources/__init__.py", line 2578, in activate
declare_namespace(pkg)
File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/_vendor/pkg_resources/__init__.py", line 2152, in declare_namespace
_handle_ns(packageName, path_item)
File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/_vendor/pkg_resources/__init__.py", line 2092, in _handle_ns
_rebuild_mod_path(path, packageName, module)
File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/_vendor/pkg_resources/__init__.py", line 2121, in _rebuild_mod_path
orig_path.sort(key=position_in_sys_path)
AttributeError: '_NamespacePath' object has no attribute 'sort'
u38476@s001-n061:~$ import pip
Command 'import' not found, but can be installed with:
apt install imagemagick-6.q16
apt install graphicsmagick-imagemagick-compat
apt install imagemagick-6.q16hdri
Ask your administrator to install one of them.
u38476@s001-n061:~$
- Tags:
- General Support
Thanks for reaching out.
Create an environment using
conda create --name envname
After creating the environment check the python path of that environment using below command.
which python
If it shows /glob path, kindly change $PATH to your current conda environment as below
export PATH="/home/uxxxx/.conda/envs/envname/bin":$PATH
Finally install seaborn library in that environment using
Hope this helps!
Was the information provided helpful?Could you give us an update?
yes. Thank you
Thanks for the confirmation we are closing the case.
