Community
cancel
Showing results for
Search instead for
Did you mean:
OSError: [Errno 30] Read-only file system: '/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/docs'
I am unable to install packages in my intel dev cloud. I tried installing packages using pip from bash shell. I also created a new conda environment and tried installing packages there. It didn't work either. I think the problem is with permissions in file system. The error says "read-only file system" as you can see.
P.S: I am trying to install keras and sklearn
please check the error log below.
Installing collected packages: keras
Exception:
  File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/commands/install.py", line 342, in run
    prefix=options.prefix_path,
  File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/req/req_set.py", line 784, in install
    **kwargs
  File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/req/req_install.py", line 851, in install
    self.move_wheel_files(self.source_dir, root=root, prefix=prefix)
  File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/req/req_install.py", line 1064, in move_wheel_files
    isolated=self.isolated,
  File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/wheel.py", line 345, in move_wheel_files
    clobber(source, lib_dir, True)
  File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/wheel.py", line 316, in clobber
    ensure_dir(destdir)
  File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/utils/__init__.py", line 83, in ensure_dir
    os.makedirs(path)
  File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/os.py", line 220, in makedirs
    mkdir(name, mode)
Tags (1)
Hey
This is because you are trying to install to the package to the python present in /glob.  This python is common to all devcloud users. You should be using --user flag to install the package specific only to your user
eg
pip install Keras --user
Hope this helps
Arun Jose
Hi Jose, Arun
I am sorry that I am quite late here. I actually found out the solution which is the same like you mentioned. Thanks for the help! Cheers!
Hey Rohit,
Thanks for the confirmation. We are closing the case as your issue is resolved. Please feel free to raise a new thread in case of further issues.
Arun Jose
