I am unable to install packages in my intel dev cloud. I tried installing packages using pip from bash shell. I also created a new conda environment and tried installing packages there. It didn't work either. I think the problem is with permissions in file system. The error says "read-only file system" as you can see.
P.S: I am trying to install keras and sklearn
please check the error log below.
Installing collected packages: keras Exception: Traceback (most recent call last): File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/basecommand.py", line 215, in main status = self.run(options, args) File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/commands/install.py", line 342, in run prefix=options.prefix_path, File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/req/req_set.py", line 784, in install **kwargs File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/req/req_install.py", line 851, in install self.move_wheel_files(self.source_dir, root=root, prefix=prefix) File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/req/req_install.py", line 1064, in move_wheel_files isolated=self.isolated, File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/wheel.py", line 345, in move_wheel_files clobber(source, lib_dir, True) File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/wheel.py", line 316, in clobber ensure_dir(destdir) File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/pip/utils/__init__.py", line 83, in ensure_dir os.makedirs(path) File "/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/os.py", line 220, in makedirs mkdir(name, mode) OSError: [Errno 30] Read-only file system: '/glob/intel-python/versions/2018u2/intelpython3/lib/python3.6/site-packages/docs'
- Tags:
- General Support
Hey
This is because you are trying to install to the package to the python present in /glob. This python is common to all devcloud users. You should be using --user flag to install the package specific only to your user
eg
pip install Keras --user
Hope this helps
Arun Jose
Hi Jose, Arun
I am sorry that I am quite late here. I actually found out the solution which is the same like you mentioned. Thanks for the help! Cheers!
Hey Rohit,
Thanks for the confirmation. We are closing the case as your issue is resolved. Please feel free to raise a new thread in case of further issues.
Arun Jose
