Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1465 Discussions
Older account environment differs from new one.
Dr_FPGA
While running OpenCL ingest example on two accounts that our company has we have found a difference that breaks execution of this example. I posted all of the details here:
https://community.intel.com/t5/Intel-oneAPI-Base-Toolkit/Ingest-OpenCL-by-source-example-fauls-to-run/td-p/1188869
Most likely the difference is environment elated. Please take a look at 2019 account u34222 and make its environment the same as 2020 account u44838 which has run GPU OpenCL example without a problem.
Thanks!
JananiC_Intel
Thanks for reaching out.
We have forwarded your request to the admin team.Also there may be a chance of data loss,so kindly make a backup of important files.
JananiC_Intel
Sorry for the delay.
Since your account which needs to be fixed is very old, the best way to resolve your issue is to apply for a new account and also there are lot of changes in the new devcloud accounts.You can apply for new account here https://intelsoftwaresites.secure.force.com/DevCloud/
JananiC_Intel
Could you give us an update?Has this issue been resolved?
JananiC_Intel
We are assuming that the solution provided helped and would no longer be monitoring this issue.Please raise a new thread if you have further issues.
