I apply the codes below to enable openvino and generate results during training
import openvino_tensorflow as otf
print(otf.list_backends())
otf.set_backend('CPU')
2022-05-30 07:50:33.449595: OVTF Summary -> 113 out of 1041 nodes in the graph (10%) are now running with OpenVINO™ backend 2022-05-30 07:50:33.533068: OVTF Summary -> 0 out of 5 nodes in the graph (0%) are now running with OpenVINO™ backend 2022-05-30 07:50:33.535766: OVTF Summary -> 0 out of 6 nodes in the graph (0%) are now running with OpenVINO™ backend 2022-05-30 07:50:33.537710: OVTF Summary -> 0 out of 5 nodes in the graph (0%) are now running with OpenVINO™ backend 1562/1562 [==============================] - ETA: 0s - loss: 4.0426 - accuracy: 0.0826 - top-5-accuracy: 0.2652
Later the display is
1562/1562 [==============================] - ETA: 0s - loss: 3.5136 - accuracy: 0.1585 - top-5-accuracy: 0.42112022-05-30 08:07:17.139680: OVTF Summary -> 0 out of 8 nodes in the graph (0%) are now running with OpenVINO™ backend 2022-05-30 08:07:17.144779: OVTF Summary -> 0 out of 14 nodes in the graph (0%) are now running with OpenVINO™ backend 2022-05-30 08:07:17.148742: OVTF Summary -> 0 out of 10 nodes in the graph (0%) are now running with OpenVINO™ backend 2022-05-30 08:07:17.151411: OVTF Summary -> 0 out of 6 nodes in the graph (0%) are now running with OpenVINO™ backend 2022-05-30 08:07:17.174284: OVTF Summary -> 0 out of 6 nodes in the graph (0%) are now running with OpenVINO™ backend 2022-05-30 08:07:17.178607: OVTF Summary -> 0 out of 6 nodes in the graph (0%) are now running with OpenVINO™ backend
2022-05-30 08:07:17.170349: W tensorflow/core/framework/dataset.cc:768] Input of GeneratorDatasetOp::Dataset will not be optimized because the dataset does not implement the AsGraphDefInternal() method needed to apply optimizations.
Does this mean that OpenVINO does not make any OpenVINO optimization?
0% run OpenVINO backend?
Hi CLi37,
Thank you for your patience and understanding, For your information, OpenVINO integration for Tensorflow is to accelerate inference of the Tensorflow model and this is not designed for Tensorflow training.
Furthermore, Intel DevCloud is not recommended for training the mode.
Here is the documentation for OpenVINO™ Integration with TensorFlow* (intel.com) you can review.
Hope this information help
Thank you
Can you share the Intel DevCloud that you are using? Is it Intel DevCloud for oneAPI or FPGA or Edge?
Thank You
Hi CLi37
we might need some time to further investigate this issue. please allow us some time to investigate it.
Thank you
Hi CLi37,
Thank you
