Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1514 Discussions
Openvino module not found in devcloud
NSVR
Openvino module not found in dev cloud's jupyter lab using terminal even after installing  it using the following link.
https://docs.openvinotoolkit.org/latest/openvino_docs_install_guides_installing_openvino_conda.html
RaeesaM_Intel
Could you please try this also :
1)     Activate the conda environment that is problematic, and check the correct executable path for the environment
>>>import sys
>>> sys.executable
Do the same in the notebook by choosing the same environment kernel and check whether the executable path is different or not.
2)     From command line, check the path where kernel.json of your problematic conda environment is located.
jupyter kernelspec list
For instance on Linux it will be: /home/{username}/.local/share/jupyter/kernels/{environment name}
Open the kernel.json located in that folder and replace the incorrect executable path, as shown below.
"argv": [
"REPLACE-THIS-WITH-THE-CORRECT-EXECUTABLE-PATH",
"-m",
"ipykernel_launcher",
"-f",
"{connection_file}"
"display_name": "heterodimers",
"language": "python"
Try this and let us know the updates.
Thanks ,
Raeesa
RaeesaM_Intel
Thank you for posting in Intel DevCloud Forum.
Please make sure that the environment path is correct.
Open a new terminal and activate the environment.
$conda activate <env-name>
$which python
If the path is different, export it manually :
$export PATH= ~/.conda/envs/<env-name>/bin/:$PATH
Also, please try installing it in a fresh environment and check whether downloading and extracting is done properly.
Thanks and Regards,
Raeesa
NSVR
Hi
I am able to import openvino in terminal. but with the same env getting error in notebook
RaeesaM_Intel
Please connect to DevCloud again and make sure that export command is correct and check whether its working fine .If issue still persists, share the export command or screenshot.
Also, you can try installing it in a new environment.
NSVR
My PATH variable is resetting and changed to default every time when I refresh the page. I am attaching two screenshots, where in terminal its working as expected but the same env is not working in notebook.
RaeesaM_Intel
We were not able to reproduce the issue from our end . Could you please try exporting the environment path in notebook ?
NSVR
Hi
Still issue is persisting please find below error
ModuleNotFoundError                       Traceback (most recent call last)
<ipython-input-2-82b2d7f92c72> in <module>()
----> 1 from openvino.inference_engine import IECore
/home/u49312/.conda/envs/onnx/lib/python3.7/openvino/inference_engine/__init__.py in <module>()
----> 1 from .ie_api import *
      2 __all__ = ['IENetwork', "TensorDesc", "IECore", "Blob", "PreProcessInfo", "get_version"]
      3 __version__ = get_version()
      4
ie_api.pyx in init openvino.inference_engine.ie_api()
constants.pyx in init openvino.inference_engine.constants()
ModuleNotFoundError: No module named 'numpy'
RaeesaM_Intel
Can you install the numpy package in your environment :
conda install numpy
and try the import statement again.
RaeesaM_Intel
>>>import sys
>>> sys.executable
"argv": [
"-m",
"-f",
"{connection_file}"
Thanks ,
Raeesa
RaeesaM_Intel
Glad that your issue got resolved. We are discontinuing monitoring this thread.
Please raise a new thread if you encounter any further issues. We would be happy to help you.
Thanks and Regards,
Raeesa
