Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1594 Discussions
PTY allocation request failed on channel 0
venovako
when trying to connect to DevCloud for oneAPI via SSH, I get this message:
followed by the usual MOTD ("Welcome to the Intel DevCloud for oneAPI Projects"...), but the shell prompt does not appear.
Ultimately, I have to kill the connection with Ctrl+C.
I can still use scp/sftp, though.
Thank you for looking into this!
EDIT/P.S.: After a few attempts the issue now seems to be resolved, i.e., normal ssh access is possible.
For your information, the shell prompt did not appear, but the shell itself was accepting input and processing commands (ls, e.g.).
Thank you anyway, and please regard the issue as closed (unless there is something I have to do to prevent it from occurring again).
Rahila_T_Intel
Thank you for posting in Intel communities.
Sorry for the inconvenience caused. Looks like that was a temporary issue. We are able to connect to DevCloud for oneAPI via SSH now. Please can you check and confirm.
I_Y_H
Hi, I have the same problem:
stty: standard input: Inappropriate ioctl for device
I can type in commands like “ls” or so and it works BUT the command prompt of bash shell does not appear at all.
If I "bash -i", I get something like below and the prompt is back:
bash: cannot set terminal process group (10069): Inappropriate ioctl for device
bash: no job control in this shell
But this prompt works imperfectly; for example, when I Tab to auto-complete a command, it does not work.
Could someone at Intel please fix this issue for us? Many thanks in advance.
KishoreVarma
Same issue, but for me even unable to type anything, stuck after oneapi notice. Can someone help?
I_Y_H
This problem disappeared for me a few hours ago but came back just now.
Whenever "PTY allocation request failed on channel 0" appeared, command prompt was then gone and the shell was frozen.
Rahila_T_Intel
venovako
Yes, I can connect without issues.
I'll accept your reply as a solution, in the hope that ssh now works for the others as well.
Thank you!
Rahila_T_Intel
Thanks for accepting our solution.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
I_Y_H
Hi Rahila,
Just to confirm that I can also ssh without any issues now.
The "PTY allocation request failed on channel 0" message disappeared.
Thanks for the help.
