Hi, everyone. I am studying the tutorial_classification_sample on JupyterLab. It runs on CPU, but I want to run it on GPU. I can see that they use this line (cpu_extension_path = os.path.expanduser("~")+"/inference_engine_samples/intel64/Release/lib/libcpu_extension.so") for the CPU implementation. What should I write for the GPU implementation? Furthermore, where is this 'inference_engine_samples' file JupyterLab? Thank you for your time.
Hi rico22,
The classification tutorial only supports CPU devices as the inference is running on the same CPU that is running the Jupyter notebook. I recomend taking a look at Reference-samples/iot-devcloud/openvino-dev-latest/developer-samples/python/benchmarkApp-python/BenchmarkApp.ipynb for additional details on how to submit job to a node with a GPU available.
1.2. Introduction
The purpose of this tutorial is to examine a sample application that was created using the Intel® Distribution of Open Visual Inference & Neural Network Optimization (OpenVINO™) toolkit. This tutorial will go step-by-step through the necessary steps to demonstrate object classification on images and batches of images. Classification is performed using a pre-trained network and running it using the Intel® Distribution of OpenVINO™ toolkit Inference Engine. Inference will be executed using the same CPU(s) running this Jupyter* Notebook.
Hope this helps!
Jesus
Hi rico22,
For your information, I wasn't able to find "tutorial_classification_sample" from OpenVINO™ Notebooks. Could you provide more information regarding the source repository of your sample?
On another note, I've successfully ran the Hello Image Classification tutorial with GPU from OpenVINO™ Notebooks. To run the tutorial with GPU, you will need to change the following command:
compiled_model = ie.compile_model(model=model, device_name="GPU")
Following the OpenVINO™ Notebooks Installation Guide, you can find the GPU extension path (openvino_intel_gpu_plugin.dll) from the following directory:
openvino_env\Lib\site-packages\openvino\libs
Hairul
Hi, Hairul. Thank you for your reply. I am working on the Intel DevCloud platform. Here's the link for the tutorial: https://notebooks.edge.devcloud.intel.com/user/u174279/lab/tree/Reference-samples/iot-devcloud/openvino-dev-latest/tutorials/classification/tutorial_classification_sample.ipynb
I would like to do inferencing on GPU, but I don't know what to write for GPU implementation. For CPU implementation, this line was written: cpu_extension_path = os.path.expanduser("~")+"/inference_engine_samples/intel64/Release/lib/libcpu_extension.so"
I would also like to know the location of the 'inference_engine_samples' file in Intel DevCloud's JupterLab environment. Thank you.
Hi rico22,
1.2. Introduction
Hope this helps!
Jesus
Thank you for your response. I appreciate it. Have a nice day.
