Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1665 Discussions
Permission Denied (Public key)
vikbhas
I am getting Permission Denied error when I try to ssh
Host devcloud
User u192603
HostName c009
Port 4036
IdentityFile ~/.ssh/devcloud-access-key-192603.txt
ProxyCommand ssh -T -i ~/.ssh/devcloud-access-key-192603.txt guest@ssh.devcloud.intel.com
The above is present in my config file.
AthiraM_Intel
Could you please replace the config file with the below one:
Host devcloud
User u192603
Also make sure you have appropriate permission to the access key file and .ssh directory. To do this, run the following commands in a terminal:
chmod 600 ~/.ssh/devcloud-access-key-192603.txt
chmod 600 ~/.ssh/config
Please follow the documentation according to your OS for detailed information:
For linux/macos : https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-linux-macos/
For Windows: https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-windows-cygwin/
If the issue still persists, please check whether you are able to access JupyterLab and let us know.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue.
Thank you
AthiraM_Intel
We have not heard back from you. Could you please give us an update? Is your issue resolved?
AthiraM_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
