Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1515 Discussions
Please install latest OpenVINO on fpga_compile & fpga_runtime nodes
STyur
Dear Sirs!
I would like to ask you to install latest Distribution of OpenVINO™ toolkit with FPGA Support (2019.R3.1) on fpga_compile and  fpga_runtime nodes.
Please install It to default location  - "/opt/intel/openvino/"
Thanks in advance.
JEYANTHKRI_N_Intel
Devcloud Admin team will not cater to requests to install packages at system level but you can install it at your home directory .
For reference go through the following url ( https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux_fpga.html ) .
please feel free to contact us in case you face any further issues.
STyur
As I can see, there was old versions OpenVINO™ toolkit already installed at system level on on fpga_compile and  fpga_runtime nodes:
/glob/deep-learning/versions/openvino_2019R1/openvino_fpga_2019.1.133/ - with FPGA plugin
/opt/intel/openvino_2019.2.275/ - w/o FPGA plugin
I just asked to update these installations.
Do I understand correctly that there will be no updates?
JEYANTHKRI_N_Intel
Hi ,
We will contact the admin team and get back to you .
JEYANTHKRI_N_Intel
Hi ,
Could you please confirm if you have gained access to Datacenter Intel AI DevCloud(https://software.intel.com/en-us/devcloud/datacenter) or FPGA Intel AI DevCloud(https://software.intel.com/en-us/devcloud/FPGA).
To use FPGA, kinldy gain access to FPGA DevCloud and for any issues on it, kindly raise a thread in  https://forums.intel.com/s/topic/0TO0P0000001AUUWA2/intel-high-level-design?language=en_US.
This link is also available in "get help" link under the section "Support" in the link https://software.intel.com/en-us/devcloud/FPGA ;
