Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1590 Discussions
Problem with connect
ghnunes
Hi, I'm trying to connect to devCloud, but it's not giving me the node number.
I'm running the commands:
ssh devcloud
qsub JobFile.txt (which sleeps 6hrs)
He gives me xxxxxx.v-qsvr-1.aidevcloud
I run qstat -xf xxxxx.v-qsvr-1.aidevcloud
I have this answer:
<Data><Job><Job_Id>962570.v-qsvr-1.aidevcloud</Job_Id><Job_Name>Jobfile.txt</Job_Name><Job_Owner>umyUser@login-2.aidevcloud</Job_Owner><job_state>Q</job_state><queue>batch</queue><server>v-qsvr-1.aidevcloud</server><Checkpoint>u</Checkpoint><ctime>1631098151</ctime><Error_Path>login-2.aidevcloud:/home/umyUser/Jobfile.txt.e962570</Error_Path><Hold_Types>n</Hold_Types><Join_Path>n</Join_Path><Keep_Files>n</Keep_Files><Mail_Points>n</Mail_Points><mtime>1631098151</mtime><Output_Path>login-2.aidevcloud:/home/umyUser/Jobfile.txt.o962570</Output_Path><Priority>0</Priority><qtime>1631098151</qtime><Rerunable>True</Rerunable><Resource_List><nodect>1</nodect><nodes>1:batch:ppn=2</nodes><walltime>06:00:00</walltime></Resource_List><Variable_List>PBS_O_QUEUE=batch,PBS_O_HOME=/home/umyUser,PBS_O_LOGNAME=umyUser,PBS_O_PATH=/glob/development-tools/versions/ispc/ispc-v1.13.0-linux/bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/vtune/2021.5.0/bin64:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/vpl/2021.4.0/bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/ospray_studio/0.7.0/bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/ospray/2.6.0/bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/openvkl/0.13.0/bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/oidn/1.4.0/bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/mpi/2021.3.0//libfabric/bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/mpi/2021.3.0//bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/mkl/2021.3.0/bin/intel64:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/itac/2021.3.0/bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/intelpython/latest/bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/intelpython/latest/condabin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/inspector/2021.3.0/bin64:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/embree/3.13.0/bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/dpcpp-ct/2021.3.0/bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/dev-utilities/2021.3.0/bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/debugger/10.1.2/gdb/intel64/bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/compiler/2021.3.0/linux/lib/oclfpga/llvm/aocl-bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/compiler/2021.3.0/linux/lib/oclfpga/bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/compiler/2021.3.0/linux/bin/intel64:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/compiler/2021.3.0/linux/bin:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/clck/2021.3.0/bin/intel64:/glob/development-tools/versions/oneapi/2021.3.0/inteloneapi/advisor/2021.3.0/bin64:/glob/development-tools/versions/oneapi/beta05/inteloneapi/intelpython/latest/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/home/umyUser/.local/bin:/home/umyUser/bin:/bin,PBS_O_MAIL=/var/mail/umyUser,PBS_O_SHELL=/bin/bash,PBS_O_LANG=en_US,PBS_O_SUBMIT_FILTER=/usr/local/sbin/torque_submitfilter,PBS_O_WORKDIR=/home/umyUser,PBS_O_HOST=login-2.aidevcloud,PBS_O_SERVER=v-qsvr-1.aidevcloud</Variable_List><euser>umyUser</euser><egroup>umyUser</egroup><queue_type>E</queue_type><etime>1631098151</etime><submit_args>Jobfile.txt</submit_args><fault_tolerant>False</fault_tolerant><job_radix>0</job_radix><submit_host>login-2.aidevcloud</submit_host></Job></Data>
My answer is not coming with <exec_host>s001-n00x...
It stopped working out of nowhere, can someone help me?
RaviranjanK_Intel
Since this is a duplicate thread of https://community.intel.com/t5/Intel-DevCloud/Problem-with-qsub/m-p/1313092#M2883 , We will continue addressing this issue in the other thread
So, can we close this case as it is duplicate?
Raviranjan
RaviranjanK_Intel
I have not heard back from you. This thread will no longer be monitored by Intel.
If you need further assistance, please post a new question.
